Basic python question
Hi guys, I am hacking away in python and I have trouble getting the data I need.
I could not find the rhinoscriptsyntax GetCursorPos in python so I looked elsewhere.
But I obviously lack the basic knowledge to understand why this isn’t giving me the X coordinate…
import ctypes as ct
currPos = ct.windll.user32.GetCursorPos()
print currPos[0]
You could use this .NET method, seems to work:
import System
# Get the mouse position
mp = System.Windows.Forms.Control.MousePosition
# Extract the coordinates
xPos = mp.X
yPos = mp.Y
print xPos,yPos
Thanks Anders!
Python surely opens a lot of doors to different libraries, and it is difficult to know how to use all this info.
I need some more help:
So now I have a script that monitors the cursor and rotates camera. It’s a “look around mode” similar to pressing Ctrl-Alt + RMB. (It’s going to become a walkaround plugin)
But the cursor lags when passing over objects, icons and viewport edges so I am wondering if I can use Rhino.UI.MouseCallback in some way, but I don’t understand how to use it… how do I even look it up?
Here is what I have built so far.
import System
import scriptcontext
import ctypes as ct
intAngle=20
rs.EnableRedraw(False)
while True:
    mp1 = System.Windows.Forms.Control.MousePosition
    rs.EnableRedraw(True)
    mp2 = System.Windows.Forms.Control.MousePosition
    if mp2.X > mp1.X:
        Xangle=(mp2.X-mp1.X)/intAngle
        rs.RotateCamera(direction=0, angle=Xangle)
    if mp2.X < mp1.X:
        Xangle=(mp1.X-mp2.X)/intAngle
        rs.RotateCamera(direction=1, angle=Xangle)
    if mp2.Y > mp1.Y:
        Yangle=(mp2.Y-mp1.Y)/intAngle
        rs.RotateCamera(direction=2, angle=Yangle)
    if mp2.Y < mp1.Y:
        Yangle=(mp1.Y-mp2.Y)/intAngle
        rs.RotateCamera(direction=3, angle=Yangle)
#    ct.windll.user32.SetCursorPos(500, 500)
#check for esc press
    if scriptcontext.escape_test(False):
        print "ESC pressed "
        MouseCallback(True)
        break      #get out of the loop
I just added GetCursorPos to rhinoscriptsyntax for SR8.
MouseCallback is a class that is subclassed to get callbacks in virtual functions. In your set-up it should do pretty much the same as what you are already doing. Here’s a sample of the same thing using the MouseCallback class instead of checking on mouse position
import System
import Rhino
class MyMouseCallback(Rhino.UI.MouseCallback):
    def __init__(self):
        self.mp1 = None
        self.mp2 = None
    def OnMouseMove(self, args):
        intAngle = 20
        self.mp2 = args.ViewportPoint
        if self.mp1:
            if self.mp2.X > self.mp1.X:
                Xangle=(self.mp2.X-self.mp1.X)/intAngle
            if self.mp2.X < self.mp1.X:
                Xangle=(self.mp1.X-self.mp2.X)/intAngle
            if self.mp2.Y > self.mp1.Y:
                Yangle=(self.mp2.Y-self.mp1.Y)/intAngle
            if self.mp2.Y < self.mp1.Y:
                Yangle=(self.mp1.Y-self.mp2.Y)/intAngle
        self.mp1 = self.mp2
cb = MyMouseCallback()
cb.Enabled = True
while True:
    Rhino.RhinoApp.Wait() #let the message pump stay alive
cb.Enabled = False
Thanks, that’s very interesting.
I put the project on hold as I need to figure out how to control the cursor in Rhino with out interfering with other programs.
I will look into this when I have SR8.
THANKS!
