I have been haunted by the prospect of unsnapping lines & nodes as far I can remember from at least 18 years ago when I picked up Rhino to practice architecture. Usually, I am keen to keep things in order because when I go to model, I will not continue with open polys; going as far as to redraw everything.
Even after all the rigor I always find myself catching this moment inside overlapping lines that are not correctly overlapping, missed corners, microns off etc. Additionally, I always try to curve Boolean & fillet, my one sin is the NURBS DRAG Command, without which kills my workflow.
Is this a drag issue?
Also, I have model that are purely orthogonal or diagonal, not to mention curvaceous, on a rarity. I check the settings, the units, but the corners & overlaps always skip a beat.
Am I making a mountain out of a molehill or is this a continuous issue. I know Rhino is used for jewelry modeling & finite fabrication, so I know something is not clicking here, especially since buildings have a larger tolerance for error.
Thoughts?..
Please see the images below of the zoom in configuration & the settings.
It’s difficult to say what’s happening here… but Rhino is definitely capable of drawing with much more precision than what you’re getting, so there must be something wrong in your process (to be honest I didn’t understand half of what you were saying)
I’d have to agree - this reads like a prose poem. I’d suggest making a clear and precise description of your problem and attach a 3DM-file that shows whatever that problem is. That will probably make it somewhat easier for people to help.
If precision is the main issue here, my best advice is to always use Osnaps, turn on “Drag Selected Objects Only” in the Mouse section of Rhino settings and set the “Object Drag Threshold” to something large (1000 pixels or whatever), so that accidentally dragging objects around becomes close to impossible.
Also remember, that if you zoom in close enough - below tolerance level - all lines and curves will eventually (visually) come apart. Without any sense of scale to your screenshots, it’s close to impossible to tell what’s going on.
I too have had this problem on occasion and it sucks. One thing I would turn on the planar option. Turn off near osnap and try to use end snap and mid if possible or in many cases.
You could try adjusting your snap radius in options -
Modeling Aids - ObjectSnapPickBoxRadius. Maybe a higher value will be more noticeable and work better for you it’s currently I think set to 7 pixels depends on the scale of your work.
