I use a script i got from Digital Substance to bake non-standard components like dimensions and text. It works by collecting these components by type name and component name, then baking them in a for loop. However, this for loop has no way of deleting items from its list after baking, which causes it to create duplicates. I don’t know how to improve the script, but i assume it shouldn’t be to hard. If anyone can point me in the right direction i’d very much appreciate it.
#imports
import Grasshopper as gh
import Rhino as rc
import ghpythonlib.components as comp
from System import *
from System.Collections.Generic import *
#Active Rhinodoc
rcdoc = rc.RhinoDoc.ActiveDoc
#Active GH document
my_ghdoc = ghenv.Component.OnPingDocument()
attr =rc.DocObjects.ObjectAttributes()
# Bake the dimensions in the specified layer called Dimensions
#if it doesn't exist it used the default
attr.LayerIndex = rcdoc.Layers.Find(L,True)
# Iterate the active objects in the current GH file and find the one of the specific type
#if there are many look for the one with the name
objs = []
obj_types = []
for obj in my_ghdoc.ActiveObjects():
my_type = obj.GetType()
obj_types.append(my_type)
#uncomment the next line if you want to see all the component types in the document
if str(my_type) == Comp_type and obj.NickName == Comp_name:
objs.append(obj)
print("found it")
#bake the component
if Bake == True:
for obj in objs:
#create an empty GUID list
ids = List[Guid]()
obj.BakeGeometry(rcdoc,attr,ids)
print("baked the dimension elements")
doc_components = obj_types
The indentation is just wrong - deindent that last if statement to the left most level:
#bake the component
if Bake == True:
for obj in objs:
ids = List[Guid]()
You have to hook up some variables. L is for layer, Bake is for button/toggle. doc_components output will give you the types of components in your GH file. Component name is the name of the specific GH component.
I think this is the original Digital Substance script. Mine is a bit different, and strangely it seems to work when i paste it into your file. I adapted it last week but i forgot exactly why or how i fixed it. I think i just simplified it by swapping the if for the AND statement. Try my script above and see if it works for you.
Right, that was my original problem. Once more, with the fix.
#imports
import Rhino as rc
#Active Rhinodoc
#Active GH document
objs = []
obj_types = []
objs.append(obj)
print("found it")
#bake the component
if Bake == True:
for obj in objs:
ids = List[Guid]()
