This workflow works just fine manually. It gets more complicated when i try to run it headlessly: i tried two approaches:
Recompute solution for whole document
Trigger the specific export document
None of the solutions seem to work. Attached you will find the .gh file as well as the Python external script. Any help would be greatly appreciated, i’m a bit lost here!
sorry to be not specific helpful but is this not a job for rhino compute… I mean there are components to run your gh function on you pc as a local server if you send them a request.
right now i sit here drink a coffee and try to figure it out by myself…unfortunatly i couldnt use your plugins to export…will test first if rhino compute spit out anything …if it works some information will follow.
@flokart Why would this not be a case for Rhino.Compute? It seems to me like Rhino.Compute is great for evaluating GH defintions headlessly and potentially scaling up to production environments?
