I made a beam element named ropes and applied internal load ONLY, but the result in the axial stress of the beam (rope) shows compression. Shouldn’t all the model be subject to tension only? There are red spots inside of the element but also on the outside, did I did something wrong in the process? or in the crosssection or supports?
Although a beam itself is in tension the axial stress can show compressive and tensile parts as the beam deforms - if you look at both sides of the beam, one is usually in tension and the other is in compression.
