Hello, just switching to Rhino Windows from Mac. On the Mac, when I select objects and choose Export Selected and the dialog window opens, the file name is automatically entered into the File name field. Is there a way in the Windows version to have the current file name default to fill the File name field?
Hello- as far as I can see that is not the case here in V8 - which is as it should be - if the name is filled in and you are not careful, you can over write the current file with a selection from it.
Thanks for the reply, Pascal. At least I know not to keep looking for that option. ![]()
This is a topic about exporting to *.dxf with a script which possibly could be tweaked to export in another format…
Thanks, Martin. I’ll take a look at that.
-P
