Hi everyone,
I often use incremental saves in Grasshopper, such as filename_01
, filename_02
, and so on. Sometimes, I need to revert to a previous version, but it can be tricky to remember what each version contains. To make it easier, I wanted to save screenshots of both the Grasshopper and Rhino canvases along with each save. The thumbnail of gh files in R8 is already useful while opening a file from inside grasshopper, but having it directly in windows as jpg’s would be useful.
Any thoughts? Obviosly I can create a python node that is triggered by button, but i’d like to be a bit more flexible
dummy code
import scriptcontext as sc
import Rhino
import Grasshopper
import os
import System.Drawing
def capture_screenshots():
# Get the Grasshopper file path and name
gh_file_path = Grasshopper.Instances.DocumentServer.CurrentlyOpenDocuments[0].FilePath
gh_file_name = os.path.splitext(os.path.basename(gh_file_path))[0]
save_directory = os.path.dirname(gh_file_path)
# Create subdirectory for screenshots
screenshot_directory = os.path.join(save_directory, "Screenshots")
if not os.path.exists(screenshot_directory):
os.makedirs(screenshot_directory)
# Define file paths for screenshots
rhino_screenshot_path = os.path.join(screenshot_directory, f"{gh_file_name}_rhino.png")
grasshopper_screenshot_path = os.path.join(screenshot_directory, f"{gh_file_name}_grasshopper.png")
# Capture Rhino screenshot
view = sc.doc.Views.ActiveView
if view:
bitmap = view.CaptureToBitmap()
bitmap.Save(rhino_screenshot_path, System.Drawing.Imaging.ImageFormat.Png)
# Capture Grasshopper screenshot
canvas = Grasshopper.Instances.DocumentEditor
if canvas:
rect = canvas.ClientRectangle
bitmap = System.Drawing.Bitmap(rect.Width, rect.Height)
canvas.DrawToBitmap(bitmap, rect)
bitmap.Save(grasshopper_screenshot_path, System.Drawing.Imaging.ImageFormat.Png)
return rhino_screenshot_path, grasshopper_screenshot_path
# Trigger the screenshot capture
if __name__ == "__main__":
rhino_screenshot, grasshopper_screenshot = capture_screenshots()
print(f"Saved Rhino screenshot to: {rhino_screenshot}")
print(f"Saved Grasshopper screenshot to: {grasshopper_screenshot}")
