Hi there! We’re writing a Rhino plugin that interacts with Grasshopper via named pipes. Each piece of communication that comes in through that pipe triggers an event that is handled by a Grasshopper component. We’ve been able to successfully add and rename groups, change param properties and so on.
However, when we try adding a new param to the canvas we get some really strange UI behavior. We’ve been expiring solution and components using GH.Instances.ActiveCanvas.BeginInvoke(new Action(() => { } ); which worked well for all of the aforementioned cases. However, when we try to add a param expiring the solution, the preview or invalidationg canvas does not really help.
@DavidRutten We do realize that Grasshopper was not designed to be thread safe and that this is not the intended use of the SDK - we’re not at all surprised to be running into issues haha. But given what we’re trying to do (add a GH param when a message comes in through the pipe) - what would be the best way to approach it? Thanks in advance!
