I just came across the asymptotic curves grid shell pavilion by Eike Schling. I would like to know if there is a possibility to create a network of asymptotic curves on any given NURB free form surface…? I tried the Bowerbird plugin, but the output curves are not smooth. Also, if asymptotic curves are only possible with the minimal surfaces. Is there a possibility to incorporate that workflow as well?
Hey Baris!
Thanks for your response, I will start looking into it. Would it be possible for you to demonstrate this workflow where a freeform surface is created, then it is optimized to minimal surface with Kiwi and then the asymptotic curves are generated with Bowerbird, or any other possible approach for that matter.
There are KIWI example files. I would suggest you start simple, and try out. For me the problem always was, the inital surface. I guess there are also surfaces, which never will work nice. Also always a question of tolerances.
Maybe you want to share your surface?
Millipede curves.gh (45.6 KB)
Hey Guys!
I gave it a try with the millipede plugin, I think I managed to get the principal curvature curves, but the output is not so smooth, is there a way to create a smooth mesh out of this…?
sorry for the late reply!
I tried it with KIWI and had no success. Had in mind to try it further but forgot about it.
Now I see, you did a nice progress with Millipede!
May I ask what the final goal is? And why a mesh?
I would guess everything is also tolerance realted. If you are planning to build it, the joints will need some gap, and the wood/metal will maybe layout smooth by itself.
Also, I just realized the strips do not unroll flat, what maybe because the millipede outcome.
So, the goal is to establish a workflow wherein we can convert any freeform surface into a minimal surface and then extract the principal curvature curves or/and the asymptotic curves for panelization. I believe they have unique properties which might help us make 90 degree nodes.
So, that is why I was asking if we can make a mesh out of the millipede curves. Because then it is super easy to panelize I guess. What are your thoughts…?
ok. I tried also a bit on asymptotic curves, a while ago. I guess not every freeformsruface works.
For me mathematical decribed sufraces worked well, as well as some stuff I tried with KIWI.
Understood, also, I was thinking if it would be possible to trace the principal curvature curves with anemone…? I think these curves would do as well, for all the generic free form surfaces. Also then we can calculate the asymptotic curves with a deviation angle which might not be 45 degrees as it is in the case of minimal surfaces. What do you think…?
