Ask about an object to follow another object (clipping plane)
excuse me sir, how do I make a regular rhino text that I made myself so that it can follow wherever the clipping plane goes/slides/moves. ? other than by grouping. thnk u
Hi Zaky -
From the brief description that you provided, grouping would be the only way to do that in plain Rhino. The images aren’t informative at all, though - can you describe the problem that you are trying to solve?
I want when I move the clipping plane, the regular text will also move along the clipping plane automatically. I don’t use labels because it has the issue that the label text size is very small when in layout, therefore I use regular text and use the “object name” text field.
Hi Zaky -
Thanks for those details.
The label text size bug is on the list as RH-77206 Assign clipping plane label to Section style
Until that gets fixed, grouping those two objects would be the only way in plain Rhino to make those move together automatically.
