Tried out R8 for the first time today. Loving the flyouts with the commands… not a big fan of the toon look… But more importantly, I installed it to see if ArrayCrv was improved and finally there is a stairlike option. .
Does anyone have a workflow to array along the curve so that the vertical increments remain the same (ie ignore the distance along the curve). Images and files attached.
Thanks for sharing Pascal. I couldn’t get it to produce the results I’m after which is probably more a reflection of my non-GH skills. Did it manually in the end with good ole’ fashion rotate and move. Will get around to learning GH one day.
