Array along curve whilst stretching arrayed objects
I’d like to array these objects along a curve whilst at the same time stretching each object so it perfectly meets each corner, is this possible?
Thanks in advance :slight_smile:
Hi @tom.sullivan
Use Flow instead of array. Measure the length of your target curve and make a straight curve of the same length - array your shape along the straight curve. Now use flow to… well, flow your shapes, using the straight line as the base curve and the curvy curve as the target. Rigid should of course be set to no.
HTH, Jakob
