Arched surface with rounded edges tutorial? Maybe SubD?
Hi…,
is there a tutorial to make a smooth arched surface with rounded edges?
This customer question pops up from time to time.
Or is this a good example for SubDs?
arched_surface_with_rounded_edges.3dm (330.8 KB)
Thanks
Michael
www.flexiCAD.com
I think you wanted to attach something different…
Maybe this can help
https://www.youtube.com/watch?v=GLKS5cZLmMg
Hi @Charles,
ups, you are right.
Thank you
Michael
Hi @JayR,
this is a nice tutorial. It’s similar to the level 2 training example.
I think my customer is looking for a simpler surface, and no patch.
Thanks
Michael
Hi Michael,
For the example given, Patch seems ok.
Are you thinking of more challenging surfaces?
Regards
Jeremy
I agree, patch is fairly satisfying result but I suspect the down side is the reverse in curvature approaching the corners.
Here’s a maybe too-complicated way - with Loose loft. With straights and true arcs on the corners, (i.e. G1 only) a really nice bubble is tricky, it seems to me.
arched_surface_with_rounded_edges_maybe.3dm (375.3 KB)
Hi Jeremy,
Pascal is right, changing curvature in the corners is not beautiful.
Thanks
Michael
Hi Pascal,
this is a very good start, but hard to get the perfect result.
I thought SubD could be the way. But I am SubD beginner. :wink:
Thank you
Michael
Hi Michael - subD might be OK but you will not get the full arc shape - it will flatten out as it approaches the edges. Also, if you can compromise the arcs on the corners, there is more you can do with surfaces as well, I would say - that is, make the corners G2 to the sides.
