Hi Guys,
Can’t figure it out how to make Arc SED convex or concave? Do I have to rotate the vector?
Thank you.
Crown.gh (13.9 KB)
Hi Guys,
Thank you.
Crown.gh (13.9 KB)
Also don’t quite understand how to control curvature ?
It is probably relates to my first question.
Crown.gh (11.9 KB)
Cheers ! Got it. It works for the second case as well. Thank you
Thank you Kim.
I made a small progress last night. But I don’t understand why second arc is straight line?
Crown.gh (17.6 KB)
Not necessarily. You just have to make sure that all input triplets which are handled by the component yield valid arc constraints. That means that no triplets should have coincident start and end-points, and the tangent vector should never be (anti)parallel to the (s, e) span. In these cases arcs are either underdefined or have infinite radius.
Thank you David
BTW, in this type of operation, it would be much easier to create a unit module and then perform a polar array.
You’ll need mesh edit and mesh+ plugins to make this work.
Thank you Kim. I was thinking the same way and started to rebuild the definition just for one segment. Previous was too messy anyway.
I was really hoping to keep it as surfaces and then create solids (with thickness say 200mm) for each piece to be able to 3D print them. With 10mm gap between each panel.
Apologies for all these questions I really appreciate your help, more I learn grasshopper more I understand how much more I still need go through.
Something like an image below…
