Hi all,
Does anyone know how the convert to arcs command works in Rhino? I have a large number of curves that I would like to approximate as a series of arcs, joined with C1 continuity. I would like to automate this process as doing so by hand is very manual and time consuming - I have been using the convert to arcs command to do this so far. I expect that scripting a module in grasshopper will be the best methodology to perform this task and learning how the convert to arcs command actually works seems like a good starting point. Any tips or guidance would be much appreciated!
