I am new to Karamba and FEM in general, so I am in the process of getting my bearings.
My goal is study how the included geometry sags as a function of decreasing modulus, thus my only load condition is gravity, with fixed supports at the tabs.
When I attempt to simulate this using Karamba, I am noticing this unexpected sagging towards the centroid of the part:
Hi @jptroise,
You need to analyze the geometry as a surface with a defined cross section rather than a solid. Please also take care of the units of the model. The deformation shows similar results to the image from SimScale.
I appreciate your response. If I understand correctly, Karamba cannot operate on an arbitrary 3D geometry - I must decompose this 3D geometry into elements that Karamba can comprehend.
What is my recourse if the input geometry is not as simple as what I have shared - perhaps with variable cross section? I see that there is the Shell Var option. Shall this be my only alternative?
