Hi, community. In project i have a lot of views and tempIates. What i did is i create one filter, set graphic overrides as i need and next i want to apply that filter with it’s override values to other views as well.
So i wonder if there is the possibility to copy filter and it’s graphic override values from one view to others in a smart way using RiR components?
Below is the filter i want to apply to other views.
Thank you!
The Rhino.Inside way would be to filter your View Templates and Views that you want to apply to and Set the Element Parameter of View Template to the View.
Thank you, Japhy! Exactly what i was looking for!
