Annual Daylight challenge
Hi guys,
I am having a bit of a challenge to define the Geometry for “LB Generate Point Grid”. The “HB Visualize by Type” looks good to me but the floors are all fragmented by the walls. I found the way to extract the geometry but the results are not convincing. I hope there is a better way to check. File Attached.
Any help?
Indoor Solar.gh (102.9 KB)
Thanks a lot!
Someone may pipe in but you’ll get quicker help on the dedicated LB forums.
I did but I am a new user there and I can not attach files yet.
Thanks!
Hi Franco -
On their forum, it should be enough to read the forum rules and a few topics that come up when you search for an issue that you are trying to solve. Spending a few minutes reading will make it so that you can attach files…
Oh, thank you! I did spend a lot of time while I was not logged in.
