Hi, in Grasshopper i am using annotations from a plugin called Elefront. Is it planned/possible to add Elefront support to Shapediver?
Br,
Br,
Hi @Morten_Kaasik we do not support this plugin as it bakes geometry in the Rhino document which is something that it is not allowed in ShapeDiver.
However, we support annotations from another plugin called FabTools but these are mainly to be exported by using the ShapeDiver Download Export component. If you want to add dimension in the 3D model, you can use this cluster LinearDimension.ghcluster (12.5 KB)
If your use case is different, please let us know.
