Annotations preview bug
Grasshopper preview does not show override value on aligned dimensions. When i bake it to rhino it works. Previously, like multiple month ago i do not remember such a bug. Any workarounds?
AnnotationsError.gh (11.8 KB)
Hi dfytz -
Please post the output from the SystemInfo command.
I’ve seen a few display-related glitches that only showed up in specific view modes or after updating. It might be worth testing with a clean file as well, just to see if the behavior is tied to the document or the annotation system itself.
Its a clean file, the gh i sent is internalized, so the file is clear by default.
Hi Wim!
Rhino 8 SR32 2026-6-9 (Rhino 8, 8.32.26160.13002, Git hash:master @ 2804b73b0f4b4feba10cb8b0b07c18fce290de93)
License type: Commercial, build 2026-06-09
License details: Stand-Alone
Apple macOS Version 26.5.1 (Build 25F80) (Physical RAM: 8GB)
Mac Model Identifier: Mac14,2
Language: en-UA (MacOS default)
.NET 8.0.14
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M2
Color LCD (1470 x 956 @ 60.00Hz)
GPU Vendor: Apple
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_DarwinFoundation1.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswift_DarwinFoundation2.dylib
/usr/lib/swift/libswift_DarwinFoundation3.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswiftCoreMediaIO.dylib
/usr/lib/swift/libswiftCallKit.dylib
/usr/lib/swift/libswiftPassKit.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/updaters/libAppleTconUARPUpdater.dylib
/usr/lib/updaters/libT200Updater.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Users/ivangrebennikov/Library/Application Support/McNeel/Rhinoceros/8.0/Plug-ins/Grasshopper (b45a29b1-4343-4035-989e-044e8580d9cf)/Libraries/GHGPU/MetalBridge.dylib
/private/tmp/mm-exhelper.dylib.s1e80V
/Users/ivangrebennikov/Library/Application Support/McNeel/Rhinoceros/8.0/MacPlugIns/BoltGen_py.rhp	"BoltGen_py"	1.0.0.0
/Users/ivangrebennikov/Library/Application Support/McNeel/Rhinoceros/8.0/MacPlugIns/ReloadGhCoff.rhp	"ReloadGhCoff"	1.0.0.0
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework	"Renderer Development Kit"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp	"Commands"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp	"Snapshots"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp	"Import_OBJ"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp	"export_xaml"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp	"QuadRemesh"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp	"export_OBJ"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp	"RDK_EtoUI"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_glTF.rhp	"Import glTF"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ShrinkWrap.rhp	"ShrinkWrap"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp	"Export SVG"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_glTF.rhp	"Export glTF"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp	"MeshCommands"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp	"Export_DAE"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp	"PDF Export"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp	"IGES Export Plug-in"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp	"Import_SVG"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp	"BlockEdit"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp	"Export_AMF"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp	"Rhino Render"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp	"Import_DST"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp	"PLY - Polygon File Format Export"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp	"Import_AMF"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp	"RhinoCycles"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/PlugIns/export_SKP.rhp	"SketchUp Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_UDO.rhp	"Moray Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_RAW.rhp	"RAW Triangle Import"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_USD.rhp	"Export USD"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_DGN.rhp	"MicroStation file import: import_DGN"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_E57.rhp	"E57 Import"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_VRML.rhp	"VRML Import"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp	"AnimationTools"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_modelio_macos.rhp	"Model IO Import"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_WAMIT.rhp	"WAMIT import"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/NamedPositions.rhp	"Named Position"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_SKP.rhp	"SketchUp Import"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp	"SectionTools"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_RAW.rhp	"Raw Triangles Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/MPlane.rhp	"MPlane"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_XGL.rhp	"XGL Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp	"Legacy Rhino Render"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_CD.rhp	"Cult3D Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_LWO.rhp	"Lightwave Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_SLC.rhp	"SLC Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_3MF.rhp	"import_3MF"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_STEP.rhp	"STEP Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_3MF.rhp	"export_3MF"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_WAMIT.rhp	"WAMIT Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_SLC.rhp	"SLC Import"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_OFF.rhp	"OFF Import"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/Squish.rhp	"Squish"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_X_T.rhp	"Parasolid Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoBonusTools.rhp	"Rhino Bonus Tools"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoLabsTools.rhp	"Rhino Labs Tools"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_M.rhp	"Import_M"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_X.rhp	"X Import"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_IGES.rhp	"IGES Import Plug-in"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_AI.rhp	"Adobe Illustrator Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_ACAD.rhp	"AutoCAD file export : export_ACAD"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp	"Displacement"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_LWO.rhp	"Lightwave Import"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_SAT.rhp	"ACIS Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_CSV.rhp	"Comma Separated Value Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_PDF.rhp	"PDFReader"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_STL.rhp	"STL Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_VDA.rhp	"VDA Import"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_STEP.rhp	"STEP Import"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_FBX.rhp	"Export_FBX"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_SolidWorks.rhp	"Solidworks Import"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_STL.rhp	"STL Import"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_RIB.rhp	"Renderman Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_FBX.rhp	"Import_FBX"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_Points.rhp	"Points Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_VDA.rhp	"VDA Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_ACAD.rhp	"AutoCAD file import: import_ACAD"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_X.rhp	"X Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/CreaseAngle.rhp	"CreaseAngle"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_3DS.rhp	"3D Studio Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_PLY.rhp	"PLY - Polygon File Format Import"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/MeshTools.rhp	"MeshTools"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_Points.rhp	"Points Import"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp	"PanelingTools"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/MeshFromPoints.rhp	"MeshFromPoints"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_VRML.rhp	"VRML/X3D Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_GTS.rhp	"GTS Triangle Import"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/SolidTools.rhp	"SolidTools"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_GTS.rhp	"GTS Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_POV.rhp	"POV-Ray Export"	8.32.26160.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp	"IronPython"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp	"Grasshopper"	8.32.26160.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp	"RhinoCodePlugin"	8.32.26160.13002
Hi dfytz -
Yea, this bug was fixed a week ago → RH-95142 Grasshopper: Dim Text Override is Not Displayed
This fix went into both Rhino 9 and 8.34. The current release of Rhino 8 is 8.32, with public releases of the 8.33 candidate. If all goes well, 8.33 will be the stable release on July 14th, and a first candidate of 8.34 will become available.
I would suggest giving the 9 Beta a spin.
thank you!
