Annotation dot question
Is there a way to make a Annotation dot not be black in color? It is heavy in ink usage as well as god awful in looks . Maybe just a border around the text? Thank you, Mark
You mean like this? Change the “Display Color”
Thank you
Thank you, I will see what that looks like .
A wireframe or ghosted would be great. I do see that white solves it for the most.
Hi @markintheozarks , you can change the transparency of the color.
Minimum opacity is 1:
Thank you , that is even better
Ha! Didn’t know that.
this is weird behavior.
for LayerColor etc. i can set 0. if I set Display Color to 0, it goes to 64.
@dale
Rhino_rhL8pwKBUn
System Info
Rhino 8 SR35 2026-9-8 (Rhino 8, 8.35.26251.13001, Git hash:master @ 3645d710f50175d8ebcf404aded5b042a481c23e)
License type: Educational, build 2026-09-08
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 128GB)
.NET 8.0.19
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 1-20-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 591.86
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-20-2026
Driver Version: 32.0.15.9186
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Users\da\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\RhinoUserTextDatabase\1.1.46-beta\RhinoUserTextDatabase.rhp “RhinoUserTextDatabase” 1.1.46.0
C:\Users\da\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\byRhinoGadget\1.6.1\byRhinoGadget.rhp “byRhinoGadget” 1.6.1.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.35.26251.13001
The Display Color picker in the Properties panel replaces an alpha of exactly 0 with 25% (64), so an object can’t end up completely invisible. Any value from 1 to 255 is kept as entered. Layer colors go through a different path that doesn’t apply that limit, which is why they accept 0. Honestly, Layer color should follow suit.
– Dale
reasonable design choice
I see the reasoning behind this, although I wonder if it introduces a slight UX inconsistency in terms of affordances. If 25% is the minimum supported opacity, wouldn’t it be more intuitive for the control to stop there rather than allow 0% and then substitute a different value? That way, the UI would better reflect the actual behaviour.
