Hi guys,
Anyone knows how to animate the loop in anemone plugin? I am trying to animate the closest vector in pufferfish similar to the example it gives.
Hi guys,
You mean in grasshopper?
Double klick on loop start.
yes, but can I record and export the loop as a animation sequence? just like animating a slider in grasshopper?
Try Browse History
in Anemone…
Have you solved the problem? I also need to reslove it.
Per HS_Kim’s suggestion, I think if you animate the slider feeding browse history, after you have run the full anemone loop, you will get an animation
