Share the simplified GH, so people can look into your problem.
Try Bison.
water flow.gh (20.2 KB)
Okay, I will try that out too… Does that work in a similar way as this? that would be great.
It has a spacial component for flow direction of water.
https://www.bison.la/
Will this plugin work in rhino 7?
yes in Rhino 7 it works fine, but the pluginn is discontinued and I heard it won’t be working anymore in rhino 8.
That’s not a good news, what alternative do we have?
… basically meaning that you’ll still be able to run that in Rhino 8 by running SetDotNetRuntime and setting that to NETFramework.
But, yes, it’s no longer maintained…
Hi @Toto,
Depends what you are looking for.
GHGis has some similar tools.
And Heron I use quite a lot.
You may also want to take a look here:
