HAL9000
1
(Rhino 7, Windows 10)
I’m analyzing a circle, drawn with the circle tool.
Analyze–>Diameter
"Select point on curve for diameter measurement. Press Enter when done. (Units=Decimal Inches)
I click a point on my circle, then press “Enter”.
Command line now says “Command:”
Ok so where is my diameter answer?
pascal
(Pascal Golay)
2
Hello- when you click, the diameter should be printed out at the command line - the command continues to let you pick points on curves until Enter.
HAL9000
3
I wish I could say it worked like that for me. But when I click the line, the command line does nothing
pascal
(Pascal Golay)
4
Do you have at least two or three lines of command history visible?
HAL9000
5
D’OH! (slapping my forehead). That was the problem. Thanks.
