Analyse Weight of Object
The version of Python that Rhino uses is IronPython 2.7, so installing 3.4.2 probably won’t do anything.
IIRC, the Mac OS already has Python (not Iron Python), but Rhino needs its own version and automatically installs it (or should anyway) if you have a recent version.
–Mitch
@duke, Mitch is correct, you have to install Python 2.7 .
Randy
I install Python 2.7 from python.org. Know I have a Python 2.7 folder in Aplications and on my mac I have already the OSX Python folders (/System/Library/Frameworks/Python.framework/Versions).
But got the same problem.
ouch… pythons everywhere :wink:
that’s a tough one for people to diagnose over the internet… somehow you’re going to have to get 2.7 in the correct place and make sure everything is going to it instead of the 2(?) other versions you have.
What kind of response are you waiting for? I’m confused.
If you test it with 10.8…
SO did I, but if you follow the instructions on the link I posted earlier, it will work. This means that you delete your current Mac OS X Phyton 2.7 (all other versions can stay) The versions in your Application folder are not relevant to Rhino or System Python.
See…
Fix OSX Python Link: http://wolfpaulus.com/jounal/mac/installing_python_osx/
I have done this twice, on Macs that had the same Exception Occurred message. Once I did it, I have never had the message again.
Randy
As a note, both Macs are still running 10.8 … just checked one here.
Randy
Yuhuuu!! I update successfully to 2.7.9 as suggested by @rhinorud and it works!!! Thanks to all for support. :blush:
Glad to hear it works … Randy
Is there a version of this out there for multiple objects?
Never mind. I already adjusted the python script.
Updated above as well…
