Getting rhinoscriptsyntax up-to-date with RhinoScript is on the to-do list.
https://mcneel.myjetbrains.com/youtrack/issue/RH-37567
– Dale
– Dale
Thank you, Dale.
The meaning that I wrote yesterday is not Python Script Editor ‘s Help but Rhinoscript Editor’ s Help does not have a notation of Methods related to History such as “ObjectChildren”.
Those Methods can be executed even though they are not written in Help.
How do I know their existence?
Dale.
I’m sorry.
Now I found it.
Dale,
I use the following method when using Methods which is in Rhinoscript (vbScript) but not in PythonScript rhinoscriptsyntax.
I write a few lines of source code including Method to be used with Rhinoscript and save it in Filename.rvb.
I execute “_-LoadScript Filename.rvb” command with Rhino.RhinoApp.RunScript method of RhinoCommon using PythonScript.
I use DocumentUserText for parameters and return values.
However, I do not think it is a smart way.
Is there a way to use Rhinoscript’s Methods in PythonScript source code?
Try this:
import System
import Rhino
def TestRhinoScript():
# The RhinoScript plug-in id
rs_id = System.Guid('1C7A3523-9A8F-4cec-A8E0-310F580536A7')
# Get the RhinoScript COM object
rs_obj = Rhino.RhinoApp.GetPlugInObject(rs_id)
if rs_obj:
rs_obj.Print('Hello from RhinoScript!')
TestRhinoScript()
– Dale
Thank you, Dale.
Successful.
Chohhh kakkoii ! (It’s cool.)
I’m very happy.
I am not good at English but I’m really glad to post it.
I was able to learn a lot.
Thank you.
It will deviate from the first theme.
From that, I also tried other Rhinoscript methods.
ReplaceGeometry, RemoveCurveKnot worked properly, including ObjectChildren.
However, RemoveSurfaceKnot does not work properly.
The message “Message: オブジェクト参照がオブジェクト インスタンスに設定されていません。” appears on the Output screen of PythonScriptEditor.
Is there a solution?
You can replace the geometry of an object from Python.
There is a nice sample at the bottom of this page:
http://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_DocObjects_Tables_ObjectTable_Replace_4.htm
Don’t know about the other problems you mentioned.
Jess
Thank you, Jess.
Yes, I have known ObjectTable.Replace Method.
And I always use it.
But, there is a reason for me to use Rhinoscript 's ReplaceGeometry Method.
When updating KinkySurface with Rhinoocomon’s ObjectTable.Replace Method in Rhinoceros 5,
it changes to Polysurface.
To avoid this, I need to create a new KinkySurface as a SingleSurface with the ObjectTable.AddBrep Method
and replace it with the geometry of the original object ID using Rhinoscript’s ReplaceGeometry Method.
