hi All,
In technical view, when you make lines with an angle or bend in it, I have noticed the rendering of the line isn’t continuous. In other words Rhino doesn’t fill in the gap in the angle between the lines. I believe there must be a technical reason for this, to do with mathematical accuracy perhaps, but I’m wondering if there is a way to correct this? I am making drawings and it would just look better if the line the line didn’t have a gap in it. I also noticed there are all sorts of strange artefacts that appear as the rendering of the lines gets larger. I really love using rhino to make drawings but I’m not quite getting the clean results I need. Could someone please shed some light on the topic, some tips for better rendering of curves in Technical View…
