Alternative of boundary surfaces
I am working grille pattern using a grasshopper.
I have worked on two options both are taking high computation time. Do we have any other better alternative, which can take a few milliseconds?
I have attached the file and screenshot.
Thank you!
FOR DISCUSS.gh (18.0 KB)
This python script might help your situation.
-Kevin
Hello Kevin,
Thanks for responding.
I have checked the component, It is taking time.
We need to reduce computation time.
Yes, but considerably faster than the Boundary Surfaces component.
Converting script from python to C# speeds it up a little more.
FOR DISCUSS_re2.gh (13.2 KB)
-Kevin
I was going to suggest the same (plus dropping typehints, but that does very little here). But, contratory to established precedent/experience, I’m getting slightly faster/similar performance with GHPython on my system:
:thinking:
Scripted method is faster with equivalent geometry.
FOR DISCUSS_re3.gh (22.7 KB)
Boundary Surfaces → 3651.04 ms.
GhPython Script → 33.68 ms.
C# Script → 29.54 ms.
Rectangular Array → 16.42 ms.
Brep Join → 80.16 ms.
Merge Faces → 1365.07 ms.
Total Time → 1461.64 ms.
-Kevin
I have worked on one more option using mesh array.
FOR DISCUSS_re3 CO.gh (15.4 KB)
