Alt key accelerator doesn't show bug
Tapping Alt should show underlined access characters in the menu.
It does so in V6, not in V8.
Can confirm, same problem here on 8.4.24037.15001
Also can attest they work fine in R7:
SystemInfo-R7
Rhino 7 SR36 2023-12-12 (Rhino 7, 7.36.23346.16351, Git hash:master @ 11a364321297eb8cdb34405a3308d8911f58706d)
License type: Commercial, build 2023-12-12
License details: Cloud Zoo
Windows 10 (10.0.17134 SR0.0) or greater (Physical RAM: 16Gb)
Primary display and OpenGL: NVIDIA Quadro P2000 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 12-1-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.99
Secondary graphics devices.
Intel(R) UHD Graphics P630 (Intel) Memory: 1GB, Driver date: 2-18-2021 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-1-2023
Driver Version: 31.0.15.3799
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\Armen\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ColorPicker\6.0.0\ColorPicker.rhp “ColorPicker”
C:\Users\Armen\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.36.23346.16351
C:\Users\Armen\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp “SectionTools”
SystemInfo-R8
Rhino 8 SR4 2024-2-6 (Rhino 8, 8.4.24037.15001, Git hash:master @ bee9cb852c752350676ca6bc7f3f6946b5bbc6b7)
License type: Evaluation, build 2024-02-06
Expires on: 2024-03-04
Windows 10 (10.0.17134 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Primary OpenGL: NVIDIA Quadro P2000 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 12-1-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.99
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.4.24037.15001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.4.24037.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.4.24037.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.4.24037.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.4.24037.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.4.24037.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.4.24037.15001
The ALT-accelerator thing works, but it is not shown in the top level menu.
On the sub menus the underlining is seen:
Hope it will be an easy fix.
RH-83243 Missing underlines in top menu
