I know this is an old thread, and probably no one with ever read this, but just in case:
I have made a lot of wings, mostly for concept work but also involved in production projects
By a lot, I mean hundreds, I worked with Boeing replacement studies, Advanced Concepts etc. for years
For example, look at the 7E7 concept used for marketing
The ‘only’ method that works is the one Pascal shows (or similar), loft to a point, loft loose etc. do not give the shape control required
The issue with the image Parker Andrew shows with the twist in the ‘wrap’ surface is a Rhino problem
‘Most’ software has a spine feature so you can control the generating curve layout
In Rhino sometimes you can get close using the ‘add slash’ function
Pascal mentions that the leading edge and trailing edge ‘don’t line up’, that is typical, tips have (and wings in general) have twist
The trailing edge does always have a thickness, ‘we’ always used .1”
You don’t want to trim to this, make the upper TE and make a copy below, surface to 2 individual curves
If you a ‘modern’ tip, where there is a distinct end to the TE, it is easer than something like the Spitfire, at some point you will need to connect the flat TE with a curved bit from the LE
