I purchased Rhino well after Autodesk bought VSR shape modelling plugin and closed it down. So i purchased Xnurbs, which is OK but i see lots of VSR use video’s and it looks amazing. With that in mind, i for the first time fired up Open Ai and asked it to help me create a VSO like plugin. The end result is quite good, but nowhere near what i would expect from VSO. But it took less than an hour, so cant complain and i can get it to refine things. I am no programmer.
Has anyone else here looked at doing this kind of thing? Obviously i have not asked it to look at code, but rather the end results.
I think you misunderstand. I have in no way copied, reverse engineered anything to do with Autodesk or any other software.
Also, i have never used or onwned a VSR licence, so i cant break a license agreement with Autodesk.
I said in my previous post that i have seen a lot of videos and it looks like a great plugin, but was too late purchase it. With that in mind, i have asked Ai to help me create tools to help me with Class A surfacing very much like VSR. No cloning or copying code ( i would not know where to start) of software here.
Autodesk does not own surfacing or the ability to match a curve or surface. Thats all i am doing.
Super interested to hear if there is any option for current Rhino to achieve the capabilities of VSR - I also missed out on that era, came to Rhino right after it went away.
Watching tutorials of VSR modeling - the MultiBlend and realtime parametics in the SurfaceBlend tools are amazing - these would find immediate and constant use in current workflows here.
The upcoming “Blend studio” plug-in will be a lot more capable than VSR for Rhino 5. It’s still under development, so I can’t tell when the programmer of the plug-in will release it, but the good news is that it already shows some quite promising results. New features are added every day.
You can check my YouTube channel where I post some videos with testing the “Blend studio” in various ways. Note that I’m not the programmer of the plug-in. I only test it and give proposals for it.
It also has an extremely powerful curve blend twin tool with capabilities that even Alias does not have.
In terms of Licencing …not much to worry about at this point.
Personal use is not detectable, not prosecutable or worthwhile prosecuting a case.
Distribution can create problems.
If it uses none of the original code, then there is no opportunity for successful legal action - it may unintentionally, but again if for use privately there is not a big enough stake (or chance of cash) for a large firm to make a legal claim.
There can be a look and feel argument which I am sure will be tested in court once the new wave of vibe coded apps gets sufficient traction to make a test case worthwhile against one of the more successful projects.
It is not going to be a small challenge to large firm’s dominance with many significant projects appearing (with mixed results). But that is very different from a private or in house project.
Smaller firms with capable software at a reasonable price will be protected.
Remember this is only a few months down the track so apps in this video are still clunky as I’m sure you have seen from other examples. Notable is many run on Linux. Pros Try AI-Cloned Engineering Tools - YouTube Linus tech tips design department.
I will look out for that. Id rather have a proper plugin that works and i understand haha!
I think also everyone is reading this the wrong way. I am not doing anything illegal or morally unfair. If i had the ability to program ( i don’t), i would create a plugin that gives me the same abilities. If i programmed a plugin from scratch myself, surely that’s up to me and nothing to do with anyone who has a similar plugin. I could even sell it. Copy code, that’s a no no, reverse engineer code, that’s a no no. Design a pluging that helps with class A surfacing, nothing wrong with that. As i do not program, Ai is a tool that could help me do it. Goes like this, ‘Hey Ai, please create a plugin that match’s curves & surfaces to G1 etc.’
That’s it, no copying. just hours of figuring out how to get it to run with python (non programmer).
That said however, i will wait to test “Blend studio” when it comes out.
Copyright is not violated if there is enough separation from original source code.
Patents are very different. Creating something that is covered by a current patent can be a violation of the patent, even if the creator never saw an example of what is covered by the patent or even knows of the existance of the patent. Patents expire after 20 years. Since VSR was originally introduced in 2011 there may be some applicable patents which are current.
All true, but remembering that patents are simply the registration of an idea to set its day of first release to the public.
Patents don’t protect anything directly. Any infringement needs to be proven in court.
Then fall into a similar argument.
In house or for solo use - difficulty of detecting, too small a financial target.
Distribution may be problematic
If patent is infringed is it worth going to court if there is not a suffiently large potential payout
LegalEagle just did an analysis of cloning software. It discusses cleanroom software development as a requirement to avoid copyright strikes and how AI creates a grey area or maybe provides a stronger.
Large firms patent, small teams do otherwise … This next bit is an AI result but seems reasonable given the size of VSR (10 to 20 employees)
“The VSR Era (2009–2013): VSR operated strictly by protecting their proprietary mathematical formulations, source code, and algorithms as trade secrets and under software copyright, rather than public patent disclosures.”
“In the specialized Class-A and NURBS CAD tooling space, small independent developers frequently avoid patenting because filing requires disclosing mathematical algorithms publicly, is expensive to maintain across jurisdictions, and can be difficult to defend against larger industry competitors.”
I think we’re getting off topic. Paul Beattie is developing a tool and sharing his progress with the community, and I think that deserves praise. As someone with no programming background who can now create small programs with the help of AI, I know the joy it brings—and the many frustrations you must have encountered along the way.
I believe Paul was simply trying to find out whether others shared his enthusiasm for how VSR worked. He has already said that he hasn’t yet managed to make his tool as good as the original, and he hasn’t said that he intends to commercialize it. He also stated that he neither owned nor looked at the original code and had not reverse-engineered the program.
All he has done is describe what he wants the tool to do and how he wants it to work, and AI has created a tool for him to use.
In my opinion, all this talk about patents, intellectual property, lawsuits, David versus Goliath, and so on is out of place.
If and when he decides to sell or share the tool, Autodesk can look into it. Really, guys, Autodesk doesn’t need advocates here. Most Rhino users, engineers, industrial designers, and architects are already familiar with intellectual property to some extent.
Kudos to Paul Beattie! Keep at it, and if you can, share some screenshots of your progress. Good luck!
