Is there a way to adjust line weights when drafting? I’ve looked under the ‘Drafting’ tab but can’t seem to see what I want.
Thanks
Ramon
Thanks
Ramon
Hi Ramon,
have a look at this: http://docs.mcneel.com/rhino/5/help/en-us/commands/printdisplay.htm
Maybe that is a good starting point to find how rhino handles line width/style
I found it useful to write a simple script to thicken lines. This script will “remember” your line thickness and use it as default next time.
ThickenLines.rvb(1.3 KB)
Dan
Okay cool. I’ll give it a go.
Cheers
Ramon
Hi Willem,
Thanks for the link. I’ll have a look at it and see if it helps.
Ramon
I just discovered a problem with the ThickenLines script I had attached. It probably didn’t work for anyone else, just as it failed to work on my new computer. If anyone is interested, here is the fixed version.
Dan
