Hi i cant see this mentioned anywhere so i must be going about it wrong (except it nearly works).
so im trying to make an eto form dynamic layout that might change the amount of rows it has depeneding on, in this case, the number of layers in a file (but for now its just a list i created at the end of the script).
i can get each of the layers on their own seperate row, but i cant seem to get the controls to follow suit.
i feel like i either need to make the control variables a method in the class (which i tried to and failed at) or im going about this in completely the wrong way, considering this is my first ever Eto form i feel its the latter.
can anyone help?
import Rhino.UI
import Eto.Drawing as drawing
import Eto.Forms as forms
class Material_assigner(forms.Dialog[bool]):
def __init__(self, material_names, layer_names):##setting up the eto form
self.Title = "Material Assigner"
self.Padding = drawing.Padding(10)
self.Resizable = False
self.checkbox = forms.CheckBox( Text = "Consider?") ##check boxes (always true to assume u want to calculate every layer
self.checkbox.Checked = True
self.dropdown = forms.ComboBox() ##dropdown menu you can edit
self.dropdown.DataStore = material_names
self.dropdown.SelectedIndex = 0
self.DefaultButton = forms.Button(Text = 'OK')
self.DefaultButton.Click += self.OnOKButtonClick
self.AbortButton = forms.Button(Text = 'Cancel')
self.AbortButton.Click += self.OnCloseButtonClick
self.selectbutton = forms.Button(Text = "Select")
##want to add a "select" button so you dont need to use layers if u dont want to
layout = forms.DynamicLayout()
layout.Spacing = drawing.Size(5,5)
for layer in layer_names:
layout.AddRow(None)
layout.AddRow(layer, self.checkbox, self.dropdown, self.selectbutton)#u can just chuck strings in layouts and it acts like a lable
layout.AddRow(None)
layout.AddRow(self.DefaultButton, self.AbortButton)
self.Content = layout
def OnOKButtonClick(self, sender, e):
self.Close(True)
def OnCloseButtonClick(self, sender, e):
self.Close(False)
def test(materials, layers):
test = Material_assigner(materials, layers);
rhinowindow = test.ShowModal(Rhino.UI.RhinoEtoApp.MainWindow)
test(["material 1", "material 2"], ["layer 1", "layer 2", "layer 3"])
Thanks a bunch in advance, im pretty stuck
