I create model cars in 1/24 scale. I have been looking for a way to create a body with a specific wall thickness (about 1.5mm) from a surface for half an eternity. The surface is a polygon mesh… see screenshots.
A relatively small offset will likely fail with complex surfaces, when the minimum radius of curvature is close to or smaller than the offset distance (the offset surface intersects itself). ShrinkWrap uses voxels (I think?) so it is a lot more forgiving with complex geometry. However, it will soften detail, so you would want to offset to the side that will not be seen.
hm i believe not, i assume it takes the vertices as a basis and wraps a surface around these though you can inflate the vertices, but that even though it sounds similar might still be different to voxels… but i am just guessing either.
yeah OffsetMesh is not good in rhino… but it can at least be used to establish some start, shrinkwrap can then still come to the rescue
You need to close your shell temporarily and use tool like Meshmixer to generate inside mesh shell after offsetting which you will use later as a cutter (boolean substraction from an original mesh).
I would love to have something like that in Rhino what will works on heavy meshes. All solutions I know won`t work with heavy meshes. For now only Meshmixer works well for me.
This is how I made that spoiler for 3d printing purposes and moulding later.
