I understand that to add component programmatically we can specify what component to add and then adding that to the document
Grasshopper.Kernel.Special.GH_Panel panel1 = new Grasshopper.Kernel.Special.GH_Panel();
this.onPingDocument().AddObject(panel1, false);
However, I would like to add dynamically by using the type extracted from:
Type type = obj.GetType();
Is there something like overload to generate new IGH_DocumentObject based on Type?
Because otherwise it means that I will need to create mapping for all the objects based on the type name?
I’d recommend using Grasshopper.Instances.ComponentServer.EmitObject() to create a new instance based on the Component id of the object you already have.
Or even use Grasshopper.Instances.ActiveCanvas.InstantiateNewObject().
Reflection is known for being „slower“. But unless you are planning to initiate a million components, this won‘t matter very much… It may also be possible that you are not initializing a component completely right. Initializing over the constructor might not be sufficient enough like in some software architectures. Although you could see this a bad design… Usually when you see the Factory pattern or similar this hints initializing over a constructor might not be enough. Don‘t know here though
I’m confused then. I thought you already had an IGH_DocumentObject in your obj variable. You only need the id in any case, which you can look up ahead of time.
I’m not entirely sure what problem you’re solving though.
Yes. The canvas method does much more. It ensures the object attributes are set up correctly. It handles initialisation codes. It adds undo data. Triggers redraws and solution updates…
