Add bitmap to layout?
The bitmap could for example be a photo. That’s not possible with any version of Rhino, right?
Adding a picture to the layout is just as getting a picture to display in the modelling world. In RH5, use PictureFrame.
Thanks @wim! I wasn’t aware of that command. What I found is that Rhino draws a rectangle around the bitmap. To make that invisible, I changed print color to white.
