Accessing rhino materials within grasshopper
hello all.
i am wondering how is oit possible to access and assign a material from rhino material library ( C:\Users*USER*\AppData\Roaming\McNeel\Rhinoceros\6.0\Localization\en-US\Render Content )
the idea would be than to be able to upload the material and use it without the whole process i described in the image. this could be sweet.
would love the help, or where to find some C# direction to start getting into it.
cheers y’all
Seems like it works out as you did it.
no do it without a ref rhino geo. thats the whole point. i want to have clean rhino. this library should be accessible without creating a shape, assigning a rhino mat > uploading it to grasshopper… exploding the attributes to finally attach to a preview component.
too long to do it each time
Got it… But in that case, even if you don’t want to create geometries in Rhino scene, at least the materials you need in your Rhino Document should be loaded first.
the question is how to access the rhino material content table … human is not the key
i wish to not load material manually to rhino. i want a Gh access directly to the folder. couldn’t find any way to upload the files so far
Hello
you didn’t try too much. Just think that David Rutten has already solved this :innocent:
So just put the name of the material file, it works for me.
If you want the list of material, it mus be doable but it will give you a long list
i didnt know that, Thanx Laurent!!!
No problem, as David said there are lot of Easter Egg in Grasshopper. So there are many functionality that are not known, documented …
I use something like that to copy the full file name of a file
https://www.extrabit.com/copyfilenames/
Mine is Clickie
http://www.defoort.com/fr/clickie
In windows if you shift+right click a file it gives an option to ‘copy as path’.
I’ve tried the same but I’m receiving an error messag which, unfortunatelly, I don’t know what means! Could you give me an advice?
Thank you in advance!!
Error|460x273
Hi - Which Rhino version are you trying this in? Please run the Rhino SystemInfo command and copy-paste the result here.
Both R6 and R7 WIP
Rhino 6 SR26 2020-5-26 (Rhino 6, 6.26.20147.06511, Git hash:master @ 7788f6214ee9335d5793cc6177985a1c745e663b)
License type: Commercial, build 2020-05-26
License details: Cloud Zoo. In use by: Daniel Petcu ()
Windows 10.0 SR0.0 or greater (Physical RAM: 7.1Gb)
Machine name: DESKTOP-A0D4U5H
Hybrid graphics system.
Primary display: AMD Radeon R7 Graphics (AMD) Memory: 1GB, Driver date: 12-27-2017 (M-D-Y).
Primary OpenGL: AMD Radeon R8 M535DX (AMD) Memory: 4GB, Driver date: 12-27-2017 (M-D-Y). OpenGL Ver: 4.5.13476 Compatibility Profile Context 22.19.180.1536
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50
Driver Date: 12-27-2017
Driver Version: 22.19.180.1536
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.26.20147.6511
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\DAN\Pedorthic Art\Pedorthic Information Modeling\RhinoGrasshopper\Grasshopper\Software\Elefront422\elefront421\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.26.20147.6511
C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 6.26.20147.6511
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.26.20147.6511
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 6.26.20147.6511
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.26.20147.6511
Rhino 7 SR0 2020-6-16 (Public Build, 7.0.20168.13075, Git hash:master @ 80dfec2e2dea70cc3db7d8429be19d655399baed)
License type: Commercial, build 2020-06-16
Expires on: 2020-07-31
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.5
C:\Program Files\Rhino 7 WIP\Plug-ins\Commands.rhp “Commands” 7.0.20168.13075
C:\Program Files\Rhino 7 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 7 WIP\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7 WIP\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.0.20168.13075
C:\Program Files\Rhino 7 WIP\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.0.20168.13075
C:\Program Files\Rhino 7 WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino 7 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 7 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.0.20168.13075
C:\Program Files\Rhino 7 WIP\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.0.20168.13075
C:\Program Files\Rhino 7 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.0.20168.13075
C:\Program Files\Rhino 7 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 7 WIP\Plug-ins\Displacement.rhp “Displacement”
Does the error occur because of material input or geometry input ?
Test the custom preview with simples inputs to track the cause of the error.
Custom preview works with simple inputs as colors.
The error message is appearing when I’m trying to use a material from library, exactly like in your example
Thanks
There is any conclusion?
Thank you!
I’m lost in this discussion. Did anyone say how one can get the list of available materials in the current Rhino file in Grasshopper? I tried what was in the above screen shots but they yield blank results when my file has close to 50 materials built-in. Also, there does not appear to be any inputs available for the material table that reads a library from a file path. Any clarification as to whether this is possible would be great. Thanks!
What’s that components name??
In Rhino 8 you can use the query model materials component
Rhino 8:
I was hoping this would work. Am I missing something?
Rhino 9 WIP has a couple more components that make the preview easier:
