Hi there,
Firstly, great work on the plugin - Mesh to Revit is a game changer!
I have installed a trial version of Conveyor to test the mesh to revit workflow and experience the following errors when attempting to select the Select Rhino File, refresh will also trigger the same error.
The element appears in the Select Elements box after closing missing licence message:
Startup Log:
Tuesday, March 24, 2020 10:32:27 PM STARTUP LOG BEGIN…
Tuesday, March 24, 2020 10:32:27 PM Check web license: False
Tuesday, March 24, 2020 10:32:27 PM Check local license: False
Tuesday, March 24, 2020 10:32:27 PM Check trial: True
Tuesday, March 24, 2020 10:32:27 PM Adding ribbon panel.
Tuesday, March 24, 2020 10:32:27 PM Adding button to ribbon.
Tuesday, March 24, 2020 10:32:27 PM Registering Dockable pane.
Tuesday, March 24, 2020 10:32:27 PM PLUGIN REGISTRATION SUCCESSFUL.
Install log
Tuesday, 24 March 2020: Beginning Conveyor Install
Tuesday, 24 March 2020: Imperial Config: LayerSetup-IMPERIAL.config
Tuesday, 24 March 2020: Metric Config: LayerSetup-METRIC.config
Tuesday, 24 March 2020: Beginning Revit 2020 install
Tuesday, 24 March 2020: Revit 2020 files installed successfully.
Tuesday, 24 March 2020: Beginning Rhino install
Tuesday, 24 March 2020: Rhino files installed successfully.
Tuesday, 24 March 2020: Install complete!
When opening Rhino Conveyor in Revit 2020 (20.2.12.)
Any thoughts on how I might be able to trial succesfully?
Cheers.
