4-sided roof
roof.gh (10.0 KB)
i want to create a 4-sided roof in this,any ideas?
thanks
Not on my pc now
Does this link help
no,that doesnt work for me,but thank you for the try
my problem is that i have a box with dimensions x,y,z with an area of 100m2
so x=slider from 5 to 20
y=100/x
z=3
how can i create a 4 sided roof of 30degrees that “transforms” as i change the slider(x)
If you work just with a rectangle it is simple geometry trigonometry.
here’s one imperfect solution.
roof.gh (19.9 KB)
BTW, angle should be in radians, I did not add it so it is up to you.
This is another way usingBoundary Volume.
roof_re.gh (15.0 KB)
How does BoundaryVolume choose which solution to pick? There are multiple solutions.
Update:
Oh, my bad, didn’t see you also create a surface from the rectangle.
thank you,it works as long as the float doesnt go higher than 10
