I’m just starting to learn about Python scripting.
I would like to write a script for a gable roof. Simply a box with a triangle on it, but as one solid. And I’m racking my brains over how best to approach it. Ideally, I’d like it to work like the "box, 3 points, height” command. And I was wondering if there’s a way to create the gable roof in advance, specify the corner points, and then define them by clicking in the drawing. It seems like such a simple task to me, yet I can’t find a easy way to create a script for it.
Basically click 4 corner points and enter a height.
Pick the four corner points starting with the shortest side. It will try to orient the roof peak between the two short sides. If it sees the first two points represent a long side, it will ask you if you want to invert. Works on unequal-sided, non-rectangular 4-sided figures as well (in theory).
There are more that I have, and they haven’t been updated in awhile, but might get you started.
I’ve already tried a number of things, but the scripts I found don’t quite meet my needs. With those, I always have to define all the points first before the solid is generated at the end. Rhino commands like _Box, _Pyramid, or _Torus, on the other hand, create the solid while the points are being selected.
Is it possible to create commands like that for my own solid shapes? Or is there a way to see how those commands are built so I can use them as a reference?
