All:! PA Tender Wireframe|690x362
I’m modeling a steam locomotive tender wishing to print it at Shapeways which has a maximum file size of 64 MB. So when my Booleaned model was saved as an STL it logged in at 187 MB! I ran it through Meshlab to settle the STL format, then popped it into my old version of Netfabb (which locked up my machine). I ran a purge – that didn’t help. The model is about 5 inches long.
Thoughts? Advice? [Cut the into 5 assemble-able sections?]
Geometry:
Valid polysurface.
closed solid polysurface with 4544 surfaces.
Edge Tally:
723 seam edges
4668 singular edges
7274 manifold edges
= 12665 total edges
Edge Tolerances: 0.000 to 0.001
median = 0.000 average = 0.000
Vertex Tolerances: 0.000 to 0.001
Render mesh: 4544 fast meshes 488518 vertices 474603 polygons
Analysis mesh: none present
Hilary Smith
Pacific NW
