I am working for shoe sole industries, and based on studies we understood we need to use 3d laser scanner. Out put of 3d laser scanner is rim coordinates several x,y,z parameters this we need to convert in to cad model, out put of cad model will give X,Y,Z,Rx,Ry,Rz points which we can use it for robots for gluing/cementing.
Can any one help us how to do it using rhino. I am using KUKA robot.
‘The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s) and may contain proprietary, confidential or privileged information. If you are not the intended recipient, you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately and destroy all copies of this message and any attachments. WARNING: Computer viruses can be transmitted via email. The recipient should check this email and any attachments for the presence of viruses. The company accepts no liability for any damage caused by any virus transmitted by this email. www.wipro.com’
hi,
please look in to this video. Laser will be scanned the sole after scanning rim data (coordinates x,y,z) will get from camera. Only x,y,z, is not sufficient to do gluing for robot since we required rx,ry,rz along with x,y,z. I want rhino to receive x,y,z, values from camera and need to create cad model as well it should map rx,ry,rz for orientation and it should send X,Y,Z, Rx,Ry,Rz to robots for gluing.
This laser most probably generates 2D coordinates (Y / Z) and a timestamp which is calculated into X.
Your points should be sorted as one laser line after another. That means you should be able to create a polyline and all polylines could be lofted into a surface. I’ve seen similar scan data of a ski…
Yes, since existing camera can give only coordinates (x,y,z) of scaned cam model and this cam model can’t be be send it to robot.
But robot required orientation (ex,ry,rz) along with x,y,z points.
Regards,
Dharshan
Ph: 7019213414
Yes you are correct, can you give me some suggestions on this.
Hello - presumably the orientation is a vector, correct? I can’t see how this information can be extracted without the target surface in Rhino - in that case it could be the surface normal at each point, for example, just a guess, but as far as I can see Rhino would need to have the surface as well as the points to be able to help.
I suppose one could interpolate the points and the resulting curve might be able to provide some help, a local curve plane orientation or something… but I am just inventing things, I do not really know what this second set of coordinates is.
