3d OBJ export for Wordpress bplugins 3d viewer
I’m using bplugins 3d viewer for Wordpress. Does anyone have any experience with this plugin? Has anyone done this successfully?
Hi Mark -
It sounds like you are not having success with this? Is there anything Rhino-specific that is getting in the way?
Thanks for following up and sorry for the delay. I export the file as an obj and make the various elements part of the model. By that I mean instead of applying a decal, I make the logo a part of the model itself and select all the materials. However, when I export it, I’m not getting a model that can be used for the Wordpress bplugins plugin. I’m at a loss at this point.
Hi Mark -
What does it look like when you open the OBJ file in some other application, or a web-based viewer such as https://3dviewer.net/?
Can you post a small 3dm sample?
It just looks like a grey model.
The image on the right is a screenshot from Rhino. Interestingly enough, the Gator Golf Tees logo on the underside came out correctly. Following Vanessa’s suggestion I assigned a material to the various parts and didn’t make either of the logos as a decal but as a physical part of the model with its own material and color attached to it. But I’m clearly missing something.
Hi Mark -
Without a 3dm file, it’s hard to say what that might be.
Hi William … I was able to load the gltf extension that was no with my Rhino 7 version. This made everything easy. Thanks for following up!
