Hi Everyone ,
Im New Into RIR , I wonder if there is any way to extract the 2D Profile Family Curves ? i aimed to use them with Sweep Nodes …
Hi Everyone ,
Hi Nawaf,
I changed the category of your post to Rhino.Inside.Revit, Rhino.Inside a general category for the various Rhino.Inside implementations. If you post in the Rhino.Inside.Revit Category it will get responded to quicker.
Can you provide more information? There are a few ways this could be interpreted. A screenshot or small file would be helpful, along with the overall workflow you are aiming for. Thanks.
Hi Japhy ,
Thanks For Your Reply .
I’ve a Parametric 2D Profiles as a Loadble Families , I want to use the profile for a Sweep Component that follow multiple curves in project , So In General i want to create a workflow that create a sweeps with ability to change the profile family or by changing the parameters of the profile itself . i Know i can achieve a similar results using Structural Beams , But i wonder if i can use the curves of a parametric 2D Profile Family by Selecting it .
Thank You Japhy , Indeed im not asking about changing Parameters , Im Asking about placing 2D Profile Families to use it as a Profile for Sweep component (of grasshopper ).
Hi @Nawaf_Albakr,
You can extract the profile of sweep like family types using something like this cluster.
RiR-StructuralTypeProfile.gh (11.4 KB)
It takes a Type and not a Family because each type may have a different size.
Does it work for you?
