Hello Forum,
I need help on replicating this semi twist insert design. I tried rails and twists, but ends up distorting in mid sweep. Please help! thanks.
Hello Forum,
Hello - please post a file with the input objects and some indication of what the desired result is.
Thank you for the quick response.
Hello - I am confused - is your question about how that is done, or is there something wrong with it that needs fixing?
Wanted to know how it’s done.
Hello - see if the attached file helps at all -
Flow
from a line to a 3d curve,(White to Green) with History.Twist
the original extrusion on its centerline (cyan) 180 degrees.WIRE_PG.3dm (1.6 MB)
