while working a lot with trees and clusters, about 80% of my bugs lead to the following 2 (well-known) issues:
empty paths do not appear inside clusters
paths of different lengths do not combine intuitively
For both cases there are solutions, e.g. passing the data path into the cluster via a separate line (case 1) or make a cluster that repeat the input lists somehow (2).
But…
…because of (1) it is not possible to define a cluster (2) that repeats the input if there is an empty path in it.
So my wish for Rhino 8 would be empty trees in clusters and the following foolprof-never-failing MatchDuplicatePaths - component:
please and thank You!!
trees-inside-cluster.gh (6.9 KB)
MDP.gh (17.5 KB)
