but when I type Import Numpy and exectue it, I get this error : “cannot import multiarray from numpy.core”
I tried to install Numpy using other package and other mean I found in the internet but it’s always the same error, and I googled to see if someone had the same problem to no avail…anyway if someone has and idea on what is the problem it will really help me.
Sorry I just saw your answer, thanks for the headings, I’m pretty sure I tried on a 32-bit machine before and it didn’t work, I guess I should re-try again. anyway here is the error screen message:
Sorry maybe this was not very clear: I am really meaning Rhino 5 32-bit, not a 32-bit machine (which in fact can only have Rhino 32 bit).
I know I had tried importing NumPy with an older version that was hosted on this page: http://www.enthought.com/repo/.iron/ but this page is no longer available…
Maybe someone else knows where it is now, or if it only a temporary issue of that webpage.
Yeah Giulio I tried with Rhino 32bit on both a 32-bit machine and 64-bit machine and it’s still displaying the same error, even on other people computer.
for thie website you linked : https://store.enthought.com/repo/.iron/ it’s the one I used, the page is still working but you have to have an account and be logged in to see the content.
I see. Well, given that the IronPython implementation has not changed in Rhino 5, it is likely that they upgraded their support to a newer version or use another initialization system.
Could you ask them what version of IronPython they support? You can see Rhino’s version like this:
import sys
print(sys.version)
On my system, this prints 2.7.4 (IronPython 2.7.4 (2.7.0.40) on .NET 4.0.30319.34014 (32-bit))
Okay since you brought back this topic tmsmendez I have been trying since yesterday to resolve this old problem and finnally today I made it work!!
basically I think since Enthought changed their index access a litte bit it screwed the installation of the module, to make it work I had to manually download all the Egg files then open .ironpkg file and edit the index to the local repository where I put the installation files.
So anyway I hope this can help other people, I will try to put a better explanation/tutorial if it’s not clear enough.
I will be needing NumPy (and possibly SciPy) and I’m not very familiar with the “architecture” behind all the Python installation used by Rhino. It would be very helpful if you could put more informations (a small tutorial would be fabulous) on how you succeeded in finally using NumPy in Rhino.
As many people said, the link to https://store.enthought.com/repo/.iron/ no longer seems to work. Has anybody found another way to install NumPy and/or SciPy and make it work with Rhino’s implemetation (IronPython 2.7)?
Once I log into the my Enthought account, I see the page you are talking about. I have successfully installed IronPython (step 1) and made it available by adding the installation path to the my user PATH environment variable (step 2).
I also downloaded the file ironpkg-1.0.0.py in a tmp directory and run the installation command:
It’s now when I try step 4 that I get the authentification error : IOError: System.IO.IOException: Échec de l’authentification, car le site distant a fermé le flux de transport. (see below the complete error transcript)
The solution to the authentication problem was posted on the Grasshopper Discussions forum: Scipy and Numpy. The idea is to bypass the problem by first downloading the eggs and proceed with the installation locally by running the script IronPython_numpy_scipy.py from the same directory:IronPython_numpy_scipy.py (1.3 KB)
Ok, I seem to be making progress. Everything seems to have installed however when I test it i get the following error:
Message: Could not add reference to assembly mtrand
This is occurring in the 32 bit version and I have the files to the rhino python search path.
Does anyone know a way around this?
Edit:
Success! after reinstalling all the packages it seems to be working correctly. For anyone else:
Step 2) Open up cmd.exe in administrator mode then type "cd C:\Program Files (x86)\IronPython 2.7"
Step 2.1) Download all the .egg files on the enthought page to C:\Program Files (x86)\IronPython 2.7 (or similar)
Step 4) use the script here and install in the same way as 3. This should install all the modules in step 4.
Continue on as described in Steve’s post up top.
Hi bmartin… I hope you could help me.
I have not been able to execute ‘C:\temp>ipy ironpkg-1.0.0.py --install’ and I have not idea why. I have followed the instruction of this discussion and also the one on here http://www.grasshopper3d.com/forum/topics/scipy-and-numpy.
I keep on getting this error message. Do you have ny idea why?
