Something like the following should work:
Option Explicit
'Script by Mitch
'Version 1 August, 2015
Call FindClosestPointsSample()
Sub FindClosestPointsSample()
Dim crvs,pt,crv
crvs = Rhino.GetObjects("Select curves to check", 4,, True)
If Not IsArray(crvs) Then Exit Sub
pt = Rhino.GetPoint("Pick reference point")
If Not IsArray(pt) Then Exit Sub
Dim cparam,cpt
Call Rhino.EnableRedraw(False)
For Each crv In crvs
cparam = Rhino.CurveClosestPoint(crv, pt)
If Not IsNull(cparam) Then
cpt = Rhino.EvaluateCurve(crv, cparam)
If IsArray(cpt) Then
Call Rhino.AddPoint(cpt)
End If
End If
Next
Call Rhino.EnableRedraw(True)
End Sub
You can pick multiple target curves with this script.
HTH, --Mitch
