Merge 4 Surfaces
Hi Everybody!
I have created a script that merges 4 surfaces. I start merging surfaces 2 by 2 using the Rhino.Command “MergeSrf”. This works fine until I try to merge the last 2 surfaces using the exact same command. I have the following error message: Can’t determine which edges to merge. Pick near edges to merge.
I don’t understand why I have an error message as it works fine when I merge the 2 last surfaces manually in Rhino.
Attached are my 4 surfaces and the rvb file:
Untitled.3dm (66.7 KB)
Merge.rvb (549 Bytes)
Thank you for your help!
Julien
You work on a name basis. After the MergeSrf command, the resulting merged surface gets the name of the first surface selected. It will probably work like this (remove the comments after the //)
Option Explicit
Dim obj1,obj2
obj1 = Rhino.ObjectsByName("PortBot", True) // first name is PortBot
obj2 = Rhino.ObjectsByName("PortTop", True)
    Call Rhino.Command("MergeSrf obj1 obj2 _Enter")
Rhino.Command "_-SelNone", 0
obj1 = Rhino.ObjectsByName("StbBot", True) // first name is StbBot
obj2 = Rhino.ObjectsByName("StbTop", True)
obj1 = Rhino.ObjectsByName("PortBot", True) //use the first name from above
obj2 = Rhino.ObjectsByName("StbBot", True) // use the first name from above
Yes I understood this. This is the reason why the last MergeSrf was being done with “PortBot” and “StbBot”.
The last MergeSrf does not work and has the following error: Can’t determine which edges to merge. Pick near edges to merge.
I would like to understand and fix this error.
Thank you for your help.
I think I’d ask for the LastCreatedObject rather than rely on object name-
If Rhino.LastCommandResult() = 0 then
obj1 = Rhino.LastCreatedObjects()(0)
something like that.
The script selects the surfaces correctly.
What I need to do is specify the “nead edges” while calling the MergeSrf function. How can I do this?
Thank you!
Julien
This is as close as I can get:
Sub Main()
	Dim obj1, obj2, merge1, merge2
	Call Rhino.UnselectAllObjects
	Call Rhino.Command("_MergeSrf _SelID obj1 _SelId obj2 _Enter")
	merge1 = Rhino.LastCreatedObjects
	If Not IsArray(merge1) Then Exit Sub
	merge2 = Rhino.LastCreatedObjects
	If Not IsArray(merge2) Then Exit Sub
	obj1 = Rhino.SelectObject(merge1(0))
	obj2 = Rhino.SelectObject(merge2(0))
	Call Rhino.Command("_MergeSrf _SelID obj1 _SelId obj2 _Smooth=_Yes _Tolerance=0.1 _Roundness=1 _Enter")
	'Call Rhino.UnselectAllObjects
End Sub
The issue is the command needs help in knowing which edges to use. This is something you cannot specify via scripting.
I’ve added a new MergeSurfaces metthod to RhinoScript for V6. This method allows you to specify “pick points.” This should help. Again, for V6 only…
Thanks Dale for the answer.
So I look forward to using the V6 release :wink:
One question:
When I call Mergesrf in Rhino (i.e. manually) it does not ask me any edge to use and the merge succeeds.
Could you explain me why the script then needs to know which edges to use?
Tks
Are you pre-selecting the objects to merge? Or are you post-selecting, in which case the command know here on the objects you picked…
I was post-selecting while proceeding manually.
If I pre-select, I have the same warning signal than my script…
