Merge two surfaces
I’m new to this forum an not a complete novice to rhinoscript and python scripting.
I am working on a script that should merge 2 surfaces as rhino command _MergeSrf ,
Is there a way to do it without directly invoking the command?
def MergeSurface():
Object1 = rs.GetObject("Select Surface 1" ,8)
Object2 = rs.GetObject("Select Surface 2" ,8)
rs.SelectObject(Object1)
rs.SelectObject(Object2)
rs.Command ("MergeSrf Smooth=No _Enter")
if name==“main”:
MergeSurface()
this works, but is there a better way?
because I need to merge multiple surfaces in one
thanks in advance
Aleksandar
Hi Alexander,
I don’t see thing on RhinoCommon that provides the functionality provided by MergeSrf. So, scripting the command is the way to go.
– Dale
Thanks for quick answer
